heater/ac fan stays on when ignition is off | Ford Explorer Forums
yodadoordonot
Austin, Texas
1992 Explorer Sport
92 Explorer Sport, V-6, 5 spd with 140k miles
I occassionally get a burnt wiring smell when I have the ac/heater blower fan turned on high. The smell stops if I turn the fan down to one of the lower speeds.
Just recently, however, the blower fan has started staying on when I turn off the ignition switch. I have to manually turn off the fan switch also, or the fan will continue to run.
Seems like maybe some contacts have finally welded themselves together. Is there a relay that controls this or is the ignition switch the culprit?
Thanks!
There is a 50 amp fuse for the heater motor.Are you hearing any squealing coming from the motor that is the first indacation that your motor bearings are going out.:(
