Heater blowing out top vents | Page 4 | Ford Explorer Forums
Great write up.
I can’t find anything for a 2016 with the stuck on defrost problem. Any guidance would be appreciated.
Great write up.
Although there doesn't seem to be anything specific to the 2016, I wouldn't be surprised if it was generally the same setup.
1. Defrost/panel/floor mode door actuator
2. RH Temp blend door actuator
3. Air inlet mode door actuator
4. Blower motor
5. Blower motor speed control
6. A/C evaporator discharge air temp sensor
7. LH Temp blend door actuator
The Mode Actuator: #1 PN# AA-5319E616-AA NATIONAL BACK ORDER PER FORD.
1.5 HOURS TO R&R.
Welcome to the Forum. :wave:
My 2015 started to only blow air out the defrost this week. I just replaced the driver's side actuator on it today. Thankfully I found this video, Since the Ford part, YH-1769 is on backorder I used a Dorman part, #604-228. I didn't use the 90 adapter like the video shows. I was able to get the back bolt out and back in with extensions and a universal. After the new actuator install, and after a few failed attempts from up top, I was able to get the back bolt started from underneath the dash.
The Ford Factory Service Manual instructions for its replacement are awful by the way...
Yes it is the defrost actuator which is located far up on driver side. I took it in to the local shop to tackle. I could not get to it myself. They estimate 3 hours work time. Thank you for your help with this.
Bought a 2017 ford explorer and everything worked fine. Now my heat isn't coming to the floor area. My feet are constantly freezing so is this what needs to happen to get it fixed?
It seems the most common problem is with the blend doors/actuators. The diagram in post #59 is for earlier model years but may still be that same for a 2017.
Yesterday I replaced the vent mode actuator. Many thanks to @Killie for instructions in post #54 and to @96xj for the video in post #65. Both were really helpful.
Actuator alignment hint:
After replacing the actuator and connecting it to the wiring harness, I struggled to align the actuator shaft with the hole in the airbox. The video in post #65 shows breaking open the old actuator, removing the shaft, inserting the shaft in the hole and then rotate the shaft to align the hole to the shaft position on the new actuator. Then you have to remove the old shaft, insert the new actuator, and hope the alignment was close enough for the actuator to push into place. Then repeat the above if the aligment is off. I did not want to try this way because the shaft on the new actuator is long enough to fit into the hole and still be able to rotate the actuator body by hand until the hole and shaft are aligned. However, trying to rotate the actuator body by hand is really difficult because the space is so tight.
I then noticed that occasionally the shaft on the new actuator was rotating by itself. I could hear the actuator motor running. I noticed that if I woke the Explorer up out of sleep mode the actuator would start turning. It would run for about a minute and then would stop. I then stumbled into an easy wake up: pull the left stalk on the steering column back towards the driver, like activating high beams. This will wake the Explorer up and the actuator shaft will start rotating.
So, from the instrument cluster opening, I used a few fingers to hold the actuator in the correct orientation with the airbox and the shaft resting at the opening of the airbox hole. I pulled the left stalk back with the other hand and the shaft started rotating until it dropped into the hole and I pushed the actuator onto the airbox. This was much simpler than what was shown in the video.
I’m guessing that the HVAC computer rotates the actuator at wake up to determine the vent door position. That is why the above works. And maybe this only works for models with electronic HVAC control. Dunno.
Note: I had the instrument cluster disconnected and the driver’s door open during the above, I’m not sure if these somehow affect the Explorer wake up.
