Heater in '97 EB | Ford Explorer Forums
Heater in '97 EB
warpjavier
Bethlehem, Pennsylvania
'97 Eddie Bauer
Hi all,
I've been reading toons of threads about heater and the blend door. Everybody if I'm not wrong have always heat even setting the temp to 60º.
My problem is, when I turn on the heater, dont matter what temp I set I always get the same temp(very hot), but if I set the temp to 60º it stop to heat and starts to blow cold air. If I'm not wrong again, my blend door is working beacuse I get cold air and I could have a temp sensor failing.
If anybody can help me in how to test the temp sensor would be great.
PS. I tried the Electronic temp control self test but I just got a spining line then all the light comes on and nothing else. Is this normal?
I would guess that your blend door shaft is in the process of failing. My EATC did the same thing for a long time............set to 80, get heat.....set to 60, get cold. It got worse and worse until it wouldn't open/close very often at all.
You could start with a simple, quick cleaning of the indoor temp sensor and see if that helps you out some. The sensor is located behind that little quarter-sized vent to the right of your radio. A q-tip and alcohol (for the qtip, not you) will clean it in a matter of seconds.
60 degrees is the lowest temp you can go, right?? I don't have my truck anymore so I cannot confirm. If so, then at 60 degrees, the system will automatically go into Max A/C mode, which will do the same function as if you pressed the "Max A/C" button. So if you get hot air even at 65 degrees, then your blend door is broken.
Hi all,
Thanks for your answers. I want to update you guys with my problem because I've been doing some tests today and I found that the problem is the blend door.
But I have a question for everyone.
What is supposed to do the white pipe conected to the temp sensor vent? , blow air or suck air? mine always blow norm temp air even if the heater is at MAX.
PS. Any suggestion to fix the blend door?
you can try.
http://www.blenddoorfix.netfirms.com/
Sid
warpjavier said:
Hi all,
