MDewell
- April 11, 2008
- Oklahoma
- 1992 Explorer 4X4
hey gang..been awhile since I've been in here, but I'm at a loss, and you guys rock at this kind of stuff...
Problem is, it was 15 degrees this morning driving 30 minutes to work...and no hot air! I froze my tail off!!
The water pump has been recently replaced, and it was blowing hot air before that...I don't believe it to be the heater core, because I don't have any fluids on my floorboard...
The blower motor works fine..it's just not blowing hot air.
The temp on the gauge does the whole windshield-wiper deal..up, down, up...maybe a bad thermostat? Would that affect the heat this bad?
I do have a small pinhole leak in the tanks on my radiator that I noticed when the radiator pressures up, but what I've been doing to buy me time is top the radiator off, then fill up the coolant reservior. I topped both of these off this morning, and it will typically get me by for about a week before I have to do it all again. I know...get it fixed. I'm tryin...but times are tough. But, it's been working good this week, until this morning.
I should mention, if it helps, that this is the coldest morning of the year, so maybe cold has something to do with a damper or something not moving because it's cold? Make sense?
Anyways...I'll check in later to see if anyone has any ideas.
