SleepAllDay408
- January 30, 2002
- tustin, ca
- 1995 eddie bauer
sometimes hot, sometimes not
I've had a number of problems with heat both in the engine and out of the vents. for a while my engine wouldn't heat up as much as it is supposed to, since changing the hot water valve and all the radiator hoses it heats up closer to where i think it should. although the heat out of the vents still isn't always hot when i have it on 90 degrees. sometimes it will go on right away and i can hear something click and out comes hot air, but other times it just continues to blow cold air. i thought about replacing the heater core, but i was advised that it probably wasn't that and plus you have the remove the entire a/c system in order to get to it, horrible design...they should have stuck with the earlier explorer model for the heater core...four bolts and its out. anyone have any suggestions for me? thanks
