Wiring a 98 Eddie Bauer with stock sub? | Ford Explorer Forums
Ex95XLT
Rollin on Dubs
Vineland
98 EB
my explorer has a stock sub and i want to install a system...head unit/sub/amp...how do i bypass the stock sub/amp? so just the sub i installed is knocking. thanks
also...i have 2 tvs/xbox and i wanna add 2 more in the visors, with that and the system...do i need a stronger alternator?
don't use the factory sub/amp w/ your new set up. it will sound like crap. bypass it all.
yea thats what im trying to do. i dont know how to bypass it tho, thats what i need to know
anyone know what to do?
how u solder it urself?
get a solder gun and some thin aluminum wire for soldering
but what do u solder together?
I don't understand your question. If you are installing a new head unit, amp(s) and sub(s), you will not "bypass" anything. You will simply wire the new head unit and amp for power and hook RCA cables and a turn on lead between the two. Speaker wire from the amp to the speakers.
One thing I do suggest is - If you are going to purchase a new head unit, amp and sub, go ahead and get a multichannel amp to power at least the front stage. You can then save up to upgrade the front speakers later.
