heating problems | Ford Explorer Forums
heating problems
Status
Not open for further replies.
katt68
halifax, nova scotia,canada
1992 xl
92 4.0 ex is acting weird. she will head up beyond normal by the gauge, boil over in the overflow tank, blow cold air through the vents when she is heating, then all of a sudden drop off to back to normal. i have replaced the thermostat but the problem still exists. please help.
How is the fan clutch?
Fan Clutch Test:
With engine off spin the fan. A light resistance should be felt. If there is no resistance or very high resistance, replace the fan clutch.
Other things can cause overheating:
Damaged water thermostat.
Damaged water pump.
Internal engine coolant leak.
Plugged radiator.
Loose/damaged drive belt
This thread is very similar to your other:
Dead Link Removed
Status
