Heim Joint Questions | Ford Explorer Forums
96XSport
OC, Ca
2003 Expo Sport
I heard Heim Joints are top of the line. Will they fit my second generation sport? If so, how many do I need? Will this make the front end stronger? What are other measures I can take to build up the front end. Are there any aftermarket torsion bars? Thanks Jeff
YOu do not have anyplace to use a heimed joint in your front suspension. they are normally used on radius arms which you do not have on a 96.
