red.EDDIE.4x4
- May 26, 2009
- Tulsa, Oklahoma
- '93 Eddie Bauer 4x4
wow...
your truck most likely won't align because you have tierods that are bent to hell. when you bend them, they get shorter, which is why you have very little thread left for adjusting.
you do not need the outer TRE's to flex hardly at all, when the truck flexes. the steering stays very close to the same angle as the beam does as it articulates. Most heims actually articulate (flex) LESS then a lot of stock balljoints and TRE's. the "cone things" are called high-misalignment spacers.
also, the superrunner steering setup is garbage, from a geometry standpoint. steer clear of kits like that.
thank you so much for your wise words..
i was simply brainstorming and wanted more information before i just went cutting up stuff and not knowing what i am doing. i just needed a person like you who knows about heims and all that jazz to give me info.
and about the tie rods bent to hell...i think you have it backwords, yes they get shorter, but i measured and they are the same length as the stock ones. these came with a bend in them and are stock, i DID NOT bend them. but the 2wd TRE is actually longer then the 4x4 TRE so i have to thread the TRE in more, thus i have no thread left. but anyway i found a solution i believe. lets hear some opinions.
i will buy a set of 4x4 couplings, and a set of 2wd couplings and cut them each in half. then i will take the 4x4 outers and weld them to the 2wd inners. does this sound acceptable?
