Newbie here to the Explorer Forums.
Having a couple Issues with my 93 Explorer Figured I would pass them through you guys to see what you think my problems are.
Just turned 177K on the OD
First problem is I'm having some front end noise, Almost sounds like im running mudd tires on the front end. The tone of the noise changes depending on how fast i go. Its not the tires. I thought maybe the front axle maybe wheel bearings ???? I got the truck from my father and he just had the dope changed in the front Axle. I thought too maybe about adding a Friction modifier ???? Any thoughts
Second I'm having a heat problem. The heat is moving from normal hot to not so hot, the thermostate is bounching up and down as well. I thought maybe a thermostate but it has been changed in the last 6 months. Maybe heater core ??????? The truck does warm up enough to drive but there is forsure a problem.
Let me know what you guys think
Thank you
Thank you
