PhantomFord
- July 26, 2011
- Petaluma, CA
- 1995 Eddie Bauer Limited
ok so last night i was being rather stupid i wanted to see if i could light up a small burnout before installing my new rims and tires to my surprise it lit one up pretty good and i just took off rolling a burnout then i noticed my od light flashing. today getting in no flashing light harsh shifts from first to second and third. then i got the flashing light and just then the motor had no power it sounded like the fuel pump was cutting out. when i shifted in to first directly it went away now it wont shift out of what feels like second cuz of the sluggish take offs no matter how hi it revs. i tried plugging a few different code readers in to the obdII which i believe is for the pcm and it says no communication i checked all the fuses and there all good. double checked and triple checked. swapping in another transmission is not a problem for me i just think maybe its something different. no check engine light just the flashing OD light and i saw the 4x4 flash a few times as well i was thinking it possibly had something to do with a loose connection to the pcm checked wires going in to transmission all appear fine.
