help 3,000 rpm at 65mph | Ford Explorer Forums
crazycoop
tulsa,ok
00 xlt and 91eb
i just got back form a trip to tulsa ok and comeing back down i was at 3,000 rpm at 65mph and it would shift hard at times all fulids are good now ive got 31's with 3.73's and im 4x4 i know i have a exhaust leak from the header gasket that im going to fix on the 15th when i get payed but it was running at around 2,500 rpm on the way up there could it be the tranny, o/d, or coumputer any help would be great
Is there a check engine light on or od lights flashing?
o/d light flashes some times like if i stop and idle to long before moving again or if i try to go wot to fast check eng. light on do to the exhaust leak
grt the codes pulled and start from there. But to me it sounds like your tranny in not engaging od.
k callled the shop no one there todaay there closed ill call them tomorrow cause i had it rebuilt not long ago
What should the rpm be on a 2003 Ford Explorer at 65 mph?
My son has been driving ours and feels it may not be going into 4 th gear.
It has about 160,000 miles and I had the tranny rebuilt at 100,000 miles
My 02 with the 4.0 is usually around 1900-2000 RPM at highway speed.
