wildcat65gt500
- December 26, 2008
- 96 xlt
Ok so my exlorer has the bank1 and 2 lean codes. Symtoms are:
Occasional rough idle (rare)
After 15-20 drive time it acts like there is no power ie; I floor it and get nothing unless I barely touch the throttle then I get some power. (common)
Engine ONLY will die and then will restart with in a minute or so.(every day)
Here is a list of what I've done:
replaced MAF and IAC and O2 sensor (2months old both)
new upper and lower intake gaskets and all gaskets in between
new plugs and wires.
checked for vacuums myself and 3 other mechanics and nothing.
cat flow test.
Pressure on fuel pump is good according to ford but they didnt do a flow test.
Im leaning towards either the fuel pump or its relay, or the EGR and is solenoid (badly corroded).
Does anyone have other ideas that I may be missing?
cat flow test.
