parrothead
- December 26, 2005
- upstate new york
- 93 eddie bauer
I just purchased a very used 93 explorer.I invested about $800 after the purchase withthe mindset that it would make a good work vehicle in upstate New York. My primary problem now is the 4x4 is not working. I've spent about $100 on junkyard parts (4x4 modual in rear cargo area and a used transfer case shift motor)neither of which has solved the issue.Worst case I have backups now. There is no response what so ever when I try to turn the 4x4 on.no clunk. no lights.nothing. I took the dashboard bezal off to tinker with the switch. After I did that I was able to notice that regaurdless or not the switch was plugged the 4x4 and the low range lights would come on AFTER I killed the engine, but very dim. I could not tell with the tinted bezal on it. Bottom line I'm going to buy a switch 2morrow. But what else could cause this. I would prefer to do this myself for the knowledge but I'm running out of good weather and would like to have 4x4 ASAP. Thanks in advance
Chris
10th Mounain Division HOOAH
because when I have your wounded
Chris
