HELP! changing lock actuator and door locked!! | Ford Explorer Forums
chooseross
Athens, GA
'98 limited
Mine is a stock 98 limited. The drivers door lock actuator went out, so I took it out and and got a new one. Before I was able to put the new one on, I had to move the truck so I buttoned up the door and moved the truck. Before I could turn around one of my kids bumped the door and closed it in the locked position. I have gotten the driver interior panel loose enough to get my hand in there and I took off the passenger side to see how the lock movement works but I can't get it unlocked!!!!!!! Does anyone know of a release from the inside of the door, or better yet a diagram of one? I'm really stuck.
I had the one on the passenger side go bad and I could lock/unlock the door with the key without any problem.
Scucci you are the mizan. That was exactly what i needed. I'm in now, gratzi.
Got to give moneyguy the credit for that post. I just found it for you. Glad it helped.
