Help,cranking problems 4.0 sohc | Ford Explorer Forums
bronco82yellow46
CLERMONT,GA
1999 EXPLORER 4.0 SOHC
Hi Guys need help . 1999 explorer 4.0 sohc when cold starts right up runs out prefect. stop and restart spins 2 to 3 rotations before cranks motor is rebuilt crank kit, new cam chains 600 miles on motor replaced fuel pump , crank sensor any ideas thank for your help BOBBY
ECT sensor?
A defective engine coolant temperature (ECT) sensor is a possibility. If the ECT sensor tells the PCM the engine is cold when it is actually warm the PCM will set the air to fuel ratio too rich. If you have access to a scanner you can easily read the ECT sensor output to see if it is reasonable. If you don't have a scanner you can measure the resistance via the wires at the disconnected PCM connector and compare the value to those in BrooklynBay's helpful threads: ECT sensor chart
