schadler
- August 14, 2002
- Allentown, PA
- Explorer '97 XLT V8 AWD
I have a barely noticable misfire only when idling. It happens only intermittently...like every 10 seconds. It seems to do this only once warmed up. It's just a little "bump" in the otherwise smooth running engine. I noticed it a lot while towing my boat the other day...but only when I came to a stop. No problems accelerating or rolling at speed. I've recently replaced the plugs, wires, and I used some Chevron Tecron fuel injector cleaner (recommended by mechanic).
Here's what I suspect: I also have a bad (leaking) passenger side exhaust manifold gasket that makes some noise. Is it possible that at idle, some air is being drawn into the exhaust manifold and confusing the O2 sensor?
Anyone else have this problem on a 302?
