Help Emptying | Ford Explorer Forums - Serious Explorations
Help Emptying
baphomet666
Bordeaux,FRANCE
Explorer.1994. 4WD
:salute:hello,
I would now like to:
- Emptying engine
- Emptying rear differential
- Emptying front differential
- Emptying automatic transmission
My Explorer now 139,187 milles, could you give me support for high quality oils to use for my Explorer.
thank you very much for your advice
engine... just pull the drain plug and change the filter
Differentials... pull the covers
Transmission, take the pan off and change the filter
I like amsoil oil, it is relatively low cost as far as synthetics go and very high quality.
:thumbsup: Find thank's
When doing the differentials you should open the fill plug first.
There have been cases where the fill plug was hard to remove. If you pull the cover off and you can't get the fill plug out you won't be able to get the new fluid back in.
~Mark
On the front differential, there is no removable cover. The only way to change the oil is with a siphon pump through the fill hole.
or to take the whole front end apart lol:p:
but if ur not leaking up front just save urself the hassle and siphon it out
Sorry, for the front I meant separate the back half of the pumpkin from the front.... siphoning works too, especially if you have a vacuum pump:D
:salute::thumbsup: Thank you all for your advice, I'll do with the cleaner vacuum of oil
.for the oil levels .I watch until time of overflow the oil of That fill hole
for rear and front differencial. And automatic transmission
I should do as this please ? for you that is very good this manoeuvre ? thank you very much
I'm sorry for my English
Dominik
