Filling for fuse box of Ford Explorer 2018 XLT | Ford Explorer Forums - Serious Explorations
IvanKaban
St. Petersburg
2018 Explorer 2.3 XLT
Hi All!
I’ve bought a 2018 Ford Explorer 2.3 XLT with empty engine fuse box.
It is really empty. Еhere is not a single fuse and relay inside the box.
I thought I would easily fix this issue. But now I’m faced with problems and I need support.
I have fuse diagram but I can’t find difference between slots of 2-pin and 3-pin fuses.
Then I am not able to find part number of pcm power relay. Please advise where I can find it.
I guess It will help me a lot if you make a good quality picture of engine bay fuse box of 2018-2019 Ford Explorer XLT.
Welcome to the Forum. :wave:
Is the fuse diagram the same one that is in your Owner's Manual? What about the cabin fusebox? Is it also empty?
Yes, the fuse diagram is the same. The cabin fusebox is OK.
Wonder what reason they could have had for removing all the fuses and relays.
Thank you for the follow-up, Ivan. :thumbsup:
