hsinc
- August 6, 2001
- Kennesaw, GA
- 92 Sport Eddie Bauer
I have a 99 Mountaineer AWD 5.0, with 69K miles. Problem is that I loose transmission fluid into transfer case. @ quarts out of transmission equals two excess quarts into transfer case. I've had input seal into the transfer case replaced. Still have problem. I was told that there may be a seal on the output side of the transmission, inside the housing that the transfer case bolts to. It would have to be on the output shaft of the transmission. Any transmission experts pout there that know if this is correct. If so is this a change at home type seal? Don't mind tackling if it is but I am not into tearing down an automatic transmission. However just a seal replacement would be OK.
Let me know if this sounds like a possible fix to my leak.
Thanks,
Harold
Thanks,
Harold
