imq707s
- July 5, 2000
- Springfield, Missouri
- 1997 Mercury Mountaineer
I've got a 97' Mountaineer (AWD w/5.0 v8) w/ 135,000 miles on it. I've got a horrible grinding noise coming from the front of my truck which feels like it's coming from the drivers side. I can feel it through the floor at speeds around 20 mpg (only if I'm turning). I've replaced about every part I can think of and the noise is still there, I'm affraid to drive it becuase I don't want to cause any more damage. It sounds like a worn bearing noise, a grinding kind of noise.
Here is some more info.
1. I can start to hear the noise at around 15mph, and as I accelerate it goes away at around 40mph.
2. If I'm driving straight around 20mph, as I turn to the right the noise gets louder, if I turn to the left it gets a little quieter.
3. At highway speeds the noise it gone....smooth as can be.
Here are the parts that I've replaced.
1. Both front wheel bearing hub assemblys.
2. Both front CV shafts
3. Front driveshaft that goes from transfercase to from differential.
4. New front rotors and brake pads.
5. And my latest attempt to fix the problem....dropping the front diff and having it completely rebuilt.
Some other troubles shooting that I've done...
1. Jack the truck up on all 4 corners, had someone get in and run it up to around 20mph and I got under the truck to listen for the noise.....NO NOISE.
2. I removed the front driveshaft and drove the truck around.....the noise was still there.
3. I took the truck to Ford and had them diagnose the problem for me. They said that they were sure it was a passenger side wheel bearing (to bad I already replaced that).
So needless to say...I'm about fed up with this problem. I've dumped way to much cash into this Mounatineer and the problem is still there. It's made the noise for the last year or so, but over the last month it's gotten really bad.
PLEASE!!....if anyone has any ideas, let me know!!
And if you have any questions that may help you solve my problem, please post them and I will reply.
It's bad enough now where I'm affraid to even drive it.
Thanks for the help guys.
