Originally posted by JTang
Underneath the plastic step panel trim is a brown/black plastic piece that can easily pop out with a flathead screwdriver. If you take that off, you'll find a small canal where all the Ford wire bundles run. You can use that, to totally keep the wires out of the way, there's plenty of room.
I would personally like to thank JTang for posting this message! It saved me countless hours of running cables under the truck (Yecchh!) for my power cable and light switch control cable for my Rack mounted lights!
I followed his directions and found the canal! Ran my cables in 30-40 Minutes!!!!!
THANK YOU JTANG!!!!!!!
Jim F.
