Help! How Remove Evap Line from Fuel Tank? | Ford Explorer Forums
mbruffey
MN, MN
1997 5.0 AWD Eddie Bauer
How do I remove the Evap Line from the top of the Fuel Tank? Black Hose w/Gray Connector to White fitting. I stole a piece of someone else's pic to illustrate. Pic shows white connector AFTER line removed. That's the condition I want to achieve! Thx, Mark
Looks like it might use the same connectors as the fuel line. If that's the case you need the disconnect tool available at local auto parts stores/horrible freight etc.
