TBMounty50
- January 29, 2011
- Northern Kentucky
- '98 Mountaineer 5.0
I'm new to the forum but not new to brakes. However, this has me dumbfounded. My driver side, front brakes seem to push all the grease out from between the contact points of the pads and bracket on my '98 v8 AWD. when this happens I get an embarrasing grinding/groaning noise. It's not the typical squealing from vibration or the squealer tabs. I've tried two sets of rotors, three different sets/types of new pads, replaced all hardware each time, replaced the caliper bracket, pins, hose and rebuilt the caliper. The pads wear evenly and the brakes stop just fine although it walks the shims off the back after a while. I've also used three different types of brake lube as well. I will clean and lube the pads, put them together and they will be fine for about three weeks. Then I have to do it all over again. Only the driver front wheel is doing this and I've thoroughly bled the system several times. I've been doing this for almost a year. I'm getting sick of it. Any advice?
