Help identifying a part? | Ford Explorer Forums
Pannadero
Alexandria, VA
2005 Sport Trac XLS 4WD
Hey guys,
Can someone please tell me what part this is? Its the part my thermostat housing bolts on to. Ive been searching for a diagram on google and one image made it look like thats part of the water pump but Im very far from certain. Id appreciate any help.
Thanks all!
***This pic is from mine***
***This is a cleaner pic of what appears to be the same part I found online***
You circled the engine head where the thermostat housing bolts down
Here is a pic of the thermostat housing installed on my explorer
That'll be the block which the thermostat housing bolts down to. Just clean that up well and use a new seal with a light amount of Ultra RTV.
I thought he was after the lower thermostat housing, which is the weak link there.
Sorry for delay. I eventually figured out what both of you said, that that is where the thermostat housing is connected to the block.
So, the reason I was curious wondering about that, is I managed to get some metal shavings in there when I had to drill out a stuck thermostat housing bolt.
I used a neodymium magnet (very securely tire off with some high tensile cord) to fish out as many as I could. I'm sure I didn't get them all, and, apart from the water pump, I'm not sure they really pose a problem. However, I was thinking about taking a small magnet and dropping it in there permanently, to catch any shavings I missed before they could travel elsewhere. I was inspired by an article I read years ago about farmers feeding cows a magnet to collect any pieces of bailing wire or other metal junk the cow accidentally eats.
What do you guys think?
I really don't think that a few metal shavings are going to bother anything.
Now if you had a whole large pile in there, perhaps.
Next time, wipe it well to remove fluids etc, then use a shop vacuum to get most little stuff out. Use a small hose taped to the end for smaller crevices, like the heater core area.
