danlong
- October 16, 2003
- Gainesville, FL
- 2001 Sport Trac 2wd - V8
Well, I guess my memory's not quite as good as it used to be.... I pulled the motor and tranny a few months ago, preparing to dive into a 5.0 swap. Before really getting involved in the swap, situations changed and I've decided to put it off for awhile, so I reinstalled the motor and tranny yesterday. While reconnecting all the electrical stuff, I've come across four items that I just can't seem to figure out where they belong. I haven't tried starting the truck yet, since I still need to relocate my battery and finalize a few other issues, but I'd like to make sure everything is connected properly the first time. Any help is greatly appreciated!
#1 - This plug splits off the loom just before the connector for the A/C evaporator that can be seen. The wires are a black, and a black/yellow stripe.
#2 - This plug is down below the clutch master cylinder, has a black and a green w/yellow stripe wire in it.
#3 - This one's below the steering shaft, and has a red, and a gray w/ yellow stripe wire.
#4 - This sensor is plugged into the side of the block below the passenger side manifold. I can't find a plug for it, but I believe this motor was swapped from another vehicle before I bought it, so maybe it was never used in my application?
