bharms0809
- March 2, 2009
- West Valley City , Utah
- 92 XLT
Hi , I am fairly new to the forum and this is my first post , but I have searched the forum and haven't found a solution to my problem so here it is . For a while now my wifes 95 Explorer has been acting up to the point that if she drives it to a couple places after she tries to start it up its a no go . The problems started a few months ago when she would start it up in the morning when the engine was cold and it would have a rough idle but it still stayed running . After thirty seconds or sometimes a little longer it would smooth out and run fine . This did not happen all of the time sometimes it would start and run fine . Lately though it has gotten worse , and if you drive it and stop somewhere the come out and try to start it up it won't run or runs so rough that it will not gain any rpm's even with your foot burried to the floorboards
. I have checked for codes , all pass on both KOEO and, KOER , No codes.......
Heres the list of parts replaced , fuel pump , fuel filter , coil pack , DPFE sensor , TPS . Parts that I checked for propper function , EGR valve , IAC valve , MAF sensor . I have a set of gaskets for the intake manifold on their way and will install them to see if this fixes the problem . If anyone knows what else I can try I would surely appreciate the help .
