HELP!!! Multiple problems! | Ford Explorer Forums
nebexplorer
Omaha, NE
2003 Explorer XLS
I recently noticed a pulsating vibration in the wheel whenever I'm on the highway (60-70 mph). When slightly turning left, it is more pronounced. So I went to check the bearings and they seem fine (no grinding noises and the wheel feels pretty solid). But I did notice that my front right wheel has a negative camber to it compared to the other wheels and the brakes seem to have more friction than all other wheels in neutral. Could It just be an issue of alignment? Or could it still be a bearing issue and I am just over looking it.
Also, my rear brake pads are wearing unevenly (thinner at top of pad) and it is eating away at my rotors...
Check to see if the brake caliber is stuck, and check those bearings again.
Just checked that passenger wheel again. No play at all... Its just stuck in that negative camber position.
