jbwilson3791
- October 6, 2012
- 2004 Ford Explorer
I have a 2004 ford explorer with only 55,000 miles but over the course of the last year almost everything that can leak has leaked and as soon as I fix one thing, another goes wrong. I love this car, but it makes me mad that i've taken immaculate care of it and still its falling apart. Anyway, I have multiple problems but here are the ones I'm not sure how to fix.
1) Leaking Refrigerant 134a from the AC manifold hose assembly. Any suggestions on how to fix this? Has anyone had luck 134a that supposedly lubricates and repairs seals? And how difficult would it be to replace this piece, I know its expensive. Pic at the bottom of page
2) I recently replaced front lower and upper ball joints on both the drive and passenger side. Ever since doing that I periodically get an ABS light (seems like it comes on sometimes when accelerating or turning, not braking hard, but goes away after shutting the car off) C1440 was the code that appeared when i plugged in my scanner, saw some people on this forum mentioning replace a cruise control switch fixing the issue but that didnt quite make sense to me so if anyone can point me in the right direction that would be awesome, thanks!
3) and Finally if anyone has a solution to why my TPMS on the dashboard never comes on I'd love to hear it (doesn't come on when you turn the key or with a flat, never has). The Ford dealership charged me 100 bucks to misdiagnose it, said I had a burn out bulb which didn't end up being the case. They then said I needed a new TPMS module, so I got one, that didn't do the trick either. Obviously not a big deal but im annoyed I can't figure it out.
