budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
sounds alot like another thread just above / below...
when you say "won't turn over", do you mean you get no starter action or no engine firing.... "won't turn over" usually refers to "no starter action" which people appear to be taking it as ... BUT a lot of people also seem to use this term for "no engine firing". Which is it????
Next, when you turn your key to "run"... DO NOT start it... does your theft lit go out????
IF not, then you may have a "antitheft issue". IF it does, then depending on your answer the earlier question about "doesn't turn over", there are more tests / observations that can be done.
