HELP Need to know which cylinder goes with which coil tower | Ford Explorer Forums
73Elsinore
Central California
'91 XLT 4x4
OK a big DUH here. Brainiac (me) installed new heads. In so doing I pulled off the entire top end to generally clean, inspect, and set right. Well at the time of teardown I was not smart enough to mark the plug wires and guess what... now I don't know where they go.
On top of this, the Chilton and Haynes manuals conflict with each other as to the coil tower numbers. Nice huh.
The engine cyl numbers are no problem. I need the coil numbers that go with.
Does anyone have an ACCURATE diagram of what cyilnder number goes with which coil tower? Preferably from the factory shop manual? Or can you go write yours down for me?
Again DDDDDDDDUUUUUHHHH :rolleyes: :confused:
Ex is a '91.
Thanks! Pete
Thanks Fantome. That thread is for an '88 BII with a conventional round distributor. My '91 Ex has the rectangular coil pack "distributor", so unfortunately that info doesn't apply.
Anybody?
