Help needed w/E-brake | Ford Explorer Forums
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
How do you get the E-brake pads off. I lost my hanes book and I just can't figure it out. I got the calipers and rotors off so I just need to know how the Pads unclip. I'm surprised noone has ever posted this before because nothing came up in a search.:rolleyes:
Ok, I just did this a couple days ago with no haynes manual and nothing i could find on here. Its not easy. And if you think getting them off is hard wait till you try and put the new ones on. This job was meant to be done without the rear axle in which would make it about 20 times easier but it is possible to work and contort your way around it and get them on and off.
Heres the way i found easiest to do it (after doing both sides differently). You don't have to follow this order just as long as everything gets done.... this is just what worked for me.
- Buy new pads and a hardware kit (all new springs, clips, adjusters, etc)
- cut/break old springs (two long and one short)
- remove spring retainers (the u-shaped flat steel thigns) from pins by compressing them with a screwdriver and sliding them over the flat end of the pin
- remove old pads
Now heres the fun part.....
- hook one long spring on back of one pad and bend over hook so it can't fall off while you're trying to make everything else fit
- place one pad in place and slide spring behind axle and under bracket (the thing that brake cable comes into back of)
- by looking at just the right anlge and probably using a screwdriver to move the spring around you can hook it onto the pad on the other side just barely
- once you have the back spring on put one of the retaing pins in through the back of the brake plate, into the brake pad and clip it with the new retaining spring. (thats sounds a lot easier than it is.... use screw drivers, needle noses, lock jaws, whatever ya need)
-now put the adjuster in place at the bottom and the small spring as well
- now put the other retaining clip and pin in the other pad
-finally, make sure everything is semi lined up and put the long spring on the front side.... i had to use screwdriver to pry, locking needle noses to pull and its still harder than helll.... but once again, its possible...
-- and now... do the other side.... :p
Removing the axle is worth the extra work
I've done it without and then had to do it over again when the rear seal started leaking. Evidently this was because the seal was damaged by heat when the pads broke up in little pieces and jammed the drums. Opening the differential and removing the keeper is quite easy. Think of it as a good time to change the differential fluid when you do the brakes. My fluid was sure nasty. On one wheel the little spring clips had rusted and wouldn't hold the shoes tight against the back plate. I hate buying hardware but these probably should be replaced when you put new shoes in or they will drag.
Yep, just replaced the rear seals this week and decided to replace the E-brakes while I was at it. Was a lot easier with the axles out, as there is little room to get the top springs on. The only bad thing is that the differential shaft lock bolt can break during removal, and ruin the rest of your day. Took about two hours to do everything.
