SpruceX
- May 23, 2004
- Cali
- 2000 5.0 E/B
If you want to get right to my questions fast froward to the type in red
Ok I changed my rear brakes because they were shot and ruined pass/side rotor. So I go to Autozone get new pads and cheapy $39.99 rotors. Had fun taking the rotors off :fire: (thank you ford) Liquid wrench some pounding some more pounding and coming to this site to make sure I wasn't going crazy then low and behold some prying they finally let loose.
So I get it all back together readjust the star screw for the e-brake to fully tightened so I could back it off till the wheel moves freely. But even with the the star screw tightened all the way it won't hold on a hill. It will hold the X on flat gound or a very slight incline but not on a hill which means I can't park in my driveway.
Now I noticed the new rotors went on real easy but seemed fine. Now is there any adjustment in the cable itself?
I had no problems with the e-brake before. I only see in the haynes manual that there is some sort of front adjuster is that a way for me to adjust the e-brake?
Thanks
Bob-bo
Thanks
Bob-bo
