natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
It does, maybe a bit louder and the engine was shaking a little. I noticed your oil pressure gauge wasn't moving up a lot. Is that the norm?
That's the sound of valvetrain noise. If it's bad enough, and mine will do this occasionally, it will have a hard time opening the valves and then that particular cylinder can't breathe. Thankfully in my case, when it does happen, it usually goes away within 5 seconds of starting the engine. I can feel shaking in my seat while that noise is going on. It's a lifter that bled down completely (total lottery when the engine stops, which valves are up and which are down) and needs to be filled with oil again.
If yours is valvetrain noise, it's a good and bad thing. Good thing is that the engine doesn't need to be rebuilt. Bad thing is that the heads need to be pulled to replace or service (may as well replace) the lifters. Personally, I've come to terms with it and am not pulling the heads. Because for both you and me, that means taking the heads to a machine shop to check them out because they're likely cracked (known failure of 1991-1992 90TM heads). If they're cracked, that means new heads. If you replace one, may as well replace both. Add in gaskets, bolts, time, fighting exhaust manifolds, plus the cost of lifters and if you decide to throw in new pushrods and rocker arms and maybe rocker arm shafts... it adds up to a cost that just ain't worth it. Doing it yourself may be $1000 in parts. Having someone else do it could be double that. That's why mine ticks and will continue to tick
To touch on what 92exp4x4 said, pumps don't usually fail. They are bathed in oil! The reason pressure is lost is due to excessive clearances in bearings due to wear/damage. Bearings and the weight of oil that the manufacturer recommends go hand in hand. They design a tolerance for a layer of oil to be pumped into. That tolerance creates a restriction, that restriction creates pressure against the flow/volume of oil that the pump creates. This pressure makes sure that oil is forced into all the bearings and goes throughout the engine. Excessive wear means that pressure isn't created and the top end, the valvetrain, suffers as a result. That may be what happened, your connecting rod bearings might be on their way out, reducing pressure to the point that your lifters no longer pump up and can't open the valves fully.
These are all maybes, guesses.
Good luck and do let us know what the mechanic finds.
