HELP PLEASE!! ASAP. ABS sensor | Ford Explorer Forums
zacharybg13
2002 Explorer XLS
Today i changed my front hub assy. Got it all done and torqued back down, go to plug in the ABS sensor and it wont plug in? Is there a trick to it, the prongs seem to line up perfectly. Help me please.
where will it not connect, at the hub or the top of the wiring harness?
Wrll thats where it will not connect by the way, it was already connected at the hub on new part.
Are the male and female plastic piece the same shape?
Look inside the plastic piece that has the male pins, make sure they aren't bent.
