Help please! | Ford Explorer Forums
Help please!
royrogillio
El Paso, TX
2001 Ford Explorer Sport
I have a 2001 Ford Explorer Sport, and i left my keys in the ignition and the battery is dead the wind shut the door and i never opened my hood :( is there a manual release to it? and if so where could i find it at?? please help! :((
Yo................1) Find a coat hanger; 2) very carefully slip the finger tips of the left hand under the top right of the drivers door; (after straightening the coat hanger) 3) Stick the coat hanger through and stab the door lock button on the inside.............be careful not to pull too hard on the door frame because it can get sprung.................
All the best and you are in the prayers................
okay cool kidd, PLEASE re read it! the battery is DEAD!!! if i push a button NOTHING WILL HAPPEN!
Your solution is in the other thread where you already asked the question, and got the answer.
Good luck
Yes, there is a "manual release":
1. Find a long, skinny, flathead screwdriver or a similar tool.
2. Walk over to the passenger side and look under the door handle. There are two small holes where the door handle passes through to the inside of the door panel.
3. Stick the screwdriver into one of these holes (I think the left one). Make sure the door handle remains down and isn't lifted any more than necessary to get the screwdriver in.
4. Feel around with the screwdriver until you hit what feels like a thin metal rod. This rod is part of the locking mechanism and is covered with a plastic mesh (you should be able to "feel" the texture of this mesh at the end of your screwdriver). It is also angled at approx 45 degree angle.
5. Use the screwdriver to push this rod up until you see your door lock pop open. It's a bit tricky due to the weird angles but you'll eventually get it open.
This info can be found in the forums if you do a search. Best of luck.
