mrjd1981
- September 7, 2012
- Pensacola
- 2001 explorer
Hello. My first true post here, but I have been a long time gawker at these forums. You have all been a great source of information to help me through the issues i've had with my explorer. But I think I may finally have a new one.
A few weeks ago I noticed the battery gauge on my explorer slightly lower then nominal.
My first instinct was battery. So I tested the battery I had and it did come up as bad according to my B&D Smart charger. I replaced the battery. But the problem did not go away.
My second thought was Alt. so I grabbed my volt meter and its testing at 14.3-14.5..........Scratched that off my list.
So I thought maybe a ground wire or something along that line. I removed all ground bolts, sanded leads and surfaces where they attach, and used new bolts. As well as sanded surfaces on the starter where the large neg attaches. No results.
So I decided to run positive lead on my multimeter to the cig lighter, and negative to a purple wire on the obd connector and it comes up saying 13.1v...
I trace the wire all the way back to the ECU and the solid purple wire coming out of near the center of the ECU. I stuck a pin in the wire and tested it at also 13.1 while running.
Any idea what this wire is, or why this wire from the ECU would be only at 13.1 and not the full 14ish?
Any other ideas why I would not be getting full voltage to dash/obd2.
I am about to replace the alt just to scratch that off the list. next I guess would be the ECU but I've never messed with those before.
