cztexas
- September 4, 2010
- College Station, TX
- 04' Limited V8 4X4
Whenever I gave a little bit sudden acceleration on gas pedal, I can hear some noise from powertrain. Like "pa pa". like loose chain or grind noise from the front? If I give a gentle gas, everything is ok. engine should be fine, since in "N", no noise.
I am thinking the transfer case. I did try 4x4 high and 4x4 low. Everything looks fine. Only the noise.
Any idea? Thank you~~~~
