Blake D
- April 1, 2001
- Bella Vista, Arkansas
- '94 XLT
I have a 1994 XLT. I have a few questions and concerns.
First what is limited slip? and what difference does it make to have a 3.73 gears or 4.01 or whatever I might have? I tried to look on the door panel it said 41 but I'm not sure if that is correct because the vehicle was previously salvage and has had paint job. The reason I question it is I seem to have the extra cooler in front of the radiator, clicking sound from rear taillight, and wiring harness for trailor lights (towing package sounds like?)
Second I dont have a roof rack or anything on the roof and would like to get a safari rack up there but I'm not sure on what is involved and if its worth it (want the extra room to carry stuff on trips and to put lights on)
Third I had my belt changed about 2 months ago at Sears and I am hearing a squeaking noise. Thought it needed tightened then found out about auto tensioner. Took it back to Sears and they sprayed some stuff on it. Didn't work. Not just moisture either, it gets better once I drive but still makes noise.
Lastly the front, I want to say transfer case , or mabye front differential housing, has stuff occasionally dripping from it. Looks kinda like dirty baby oil with same texture, doesn't leak much just sometimes. Break fliud and other fluids have been checked and seem fine (Power steering mabye a litle high)
Putting BFG TAKO's 31x10.5x 15 on Monday
Sorry if this is too long just couldn't find any answers directly to these questions and this is my first post.
Thanks for the help guys, If I can figure out how my vehicle is set up and fix its problems I am going to make it a little more off road worthy.
Thanks Blake
Thanks Blake
