Help with Sub enclosure | Ford Explorer Forums
stryfe
Louisiana
08 Sport Trac XLT
The last of my parts should be on their way...so it's time for me to start thinking about building an enclosure. I've played around with some of the online calculators, but would like to get some recommendations.
Box size limitations.
6tall, 16wide, 14deep(under rear passenger seat) Not sure how much to allow for excursion...not this sub will have much....is the excursion directly related to, or the same as Xmax?
Sub specifications (ts-sw1001s4 Pioneer premier shallow mount)
Revc 3
Levc 2.52
Zmax 46.51
Fs 41.6
Qms 13.21
Qes 1
Qts .93
Vas .363
RMS 3.576
Mms 179.79
Sd 55
BL 12.44
Xmax .21
Hvc .81
Hag .39
What's the best resource to help a noob figure the dimensions of the box? Online calculator?
recommended volume .45 cu.ft.
max .7
min .35
qts is high as hell....sealed enclosure for sure
definitely planned on a sealed enclosure box size has to increase with non sealed
perhaps behind the seat....could get away with
16x5x33
May be the better option
