Help with the torsion twist lift and need it fast. | Ford Explorer Forums
snafu4u2s
Dagsboro, Delaware
99 Explorer Sport
ok i have just a slight problem with my 99 explorer sport... over the weekend, i decided to install the 3 inch ranger kit, warrior shackles, springs from a 99 four door explorer, the pro comp add a leaf kit, and some OME shocks. when i was finished, i planned to have my local mechanic do an alignment along with the torsion bar twist. this is were the problem is at. when i dropped it off to get the work done, he went to do the lift and found out the my driver side bar was already fully tightened and the passenger side could only be tightened about 2 turns at the stock settings. my delema is how can i lift the front up to match everything else. the front currently sits about 1.5" lower than the rear and has that muscle car look going on. not eactly want i wanted. first the back end sagged and now the front takes a dive. any ideas on how i could correct this. could changing the bars do anything or changing anything else? i appreciate the help.
ditto
Longer bolts. 100mm.
Grade 5 (I think). 8.8 will be the strength number on the tops.
Karl
