wow
okay listen up
twisting your torsion bars does not give you more shock travel
all you are doing is adjusting your vehicles ride height so you can fit bigger tires
adjusting the ride height means you are pushing the suspension down by inserting a stiffer spring, stiffer spring rate = holds up more weight
this does not mean you just gained 4" of suspension travel, you have the exact amount of suspension travel you had before, just now its less room to move down (droop) and more room to move up (bump)
so stock length shocks will work with any amount of torsion twist you do
blaming the tt for breaking your shock is retarded, a part failed or it was the wrong shock, simple as that
You dont need longer or shorter shocks for a TT, you need stock length and application shocks, stock length shocks will extend beyond your lower control arm, even with the suspension at full droop, if allowed to do so
simply cranking the bolt all the way in is no way to do a torsion twist and the last thing you want to do is lift it more then you need, it will cause excessive wear on cv axles, steering, tires, ball joints, and even your torsion bars, plus it will ride like a ghetto wagon
hope that brings the clarity
