Gregory w Bender
- February 20, 2018
- New York
- 2000 explorer spo Utility
I have a 2000 explorer with automatic transmission. When i get up to or around 40 mph it seems to buck or joint but after get pass 50 mph is goes just find. I check the transmission fluid and it's right where is got to be. I check it running and not running and its right at the spot it got to be. it's like it drops out of gear then right back in. I have no check engine light on. I know the abs wheel sensors are bad all 3 of them and both temps sensors are bad too. The abs sensors on the bad works off and on. My friend plug his abs scanner in and took it for a drive and the two front ones ain't putting out nothing and the back one it putting out a signal off and on. I don't know if the abs sensors work the transmission too. For the last month we had the suv it's been working find this just started a few days ago. Well thanks for the help i can get.
