ddrag
- August 24, 2014
- Champaign, IL
- 2001 sport trac 4wd
Hi all,
I have noticed my battery voltage dropping slowly this week and today the battery was dead. This is a 5 year old battery and I figured it was time to replace it. I took the truck in today and had a load test done and the battery, alternator, and starter all tested good. The voltage regulator, however, failed the test. I bought the replacement part but it won't be in until Tuesday. I got the truck home and removed the battery to give it a charge so I can get to work in the morning. The truck sat for about an hour before I removed the battery and when I got it out it was boiling hot. I cannot imagine why this would be if the alternator was not even getting the proper voltage to the battery. If it was overcharging, that would explain the heat. I really need this vehicle the next few days and was wondering if it is safe to drive with a bad regulator like this or if anyone has an explanation for the temp issue. Also, if any of you are familiar with this style alternator, is there anything I should know about replacing the regulator before I rip it out? Any help is greatly appreciated.
