help with wheels | Ford Explorer Forums
help with wheels
cr4ig
98 v6
hi all just after some help im a complete noob when it comes to this been looking for some new wheels looking at these
275\40\r20 there off a Porsche Cayenne load index 106
or been looking at the bmw\audi wheels how do i find out if there fit ?
regards
mines a 98
you will have to find out what the bolt pattern is and not only that you should see what offset they are so you can see if there will be clearance issues...the size of the tire and rim should work, but like i said check your bolt pattern and offset
thanks the the replys i've found the bolt pattern for the porsche is 5x130 and offset 60 so my explorers 5x114.3 offset 40 hmmm so is there anyway i can make these fit?
probaly not cause safty is a factory
ok so i got better idea can anyone steer me in direction of any 4wd that the wheels will pretty much go straight on looking at 19 or 20s
i was up most of the night searching it out i think i found out what fits and what don't :thumbsup: now just 1 question i'm a bit limited as to what i can get in the uk as most of the exact fits are on american cars and i cant afford to import some so is there anyway....... i want some nice big wheels like range rover is there anyway i can get them to fit
regards
