jpurdie
- November 29, 2010
- Palmdale, CA
- 93 Eddie Bauer
Hi
This is my first post on ExplorerForum. I have a '93 Explorer Eddie Bauer with 150k miles. 4.0L, automatic
A few weeks ago it started acting up.
The Explorer will start up just fine and drives like normal, after I stop the engine ether after a short trip or long trip when I go to restart it the engine cranks over just fine but it won’t start, it acts like it wants to start but it won’t, after I wait anywhere from 15 min to an hour it will start up just fine and drives normal until I shut it off again.
I can go on long trips 100+ miles and it runs just fine as long as I don’t shut it off.
I have read 1000’s of post on this site and others but can’t figure it out.
I have taken it to 2 shops and both shops could not get it to repeat the no start condition, 1 shop even had the Explorer 3 days and could not get the problem to repeat. He even put 20miles on the car so I know he was trying.
Both shops said NO bad codes have come up. I don’t have a code reader so I’m only going by what they said.
Here is what I have done so far in the last 2 weeks to try and fix the problem.
Replaced the fuel filter (Fram filter)
Replaced the complete fuel pump assembly (Motorcraft part) Thanks to this site for the info on cutting an access hole in the body.
Replaced both the fuel pump and EEC relays with new relays (ACDelco part)
Replaced both battery cables, positive and ground
Replaced Crankshaft Position Sensor (Motorcraft part)
I cleaned the Mass Air Flow unit
I had the plugs and wires replace about 4 month ago prior to having this problem (Motorcraft wires, BOSCH plugs)
I have tested with fuel pressure gauge when I get the no start condition and I get 32psi at the rails
When the cars running I get 30psi, and 37psi when I disconnect the vacuum line from the fuel pressure regulator.
Never seen any fuel leaking from the vacuum line from the fuel pressure regulator when I have disconnected it.
If I spray starting fluid in it, it starts but dies right away, that’s what makes me thinks it’s a fuel problem.
I have not test to see if it’s getting spark at the plugs in no start condition, but will try today.
I have not tried testing the fuel injectors (not sure how to do that)
I have tried disconnecting a few of the sensors when I get the no start condition and still it won’t start except one time I disconnected the Air Charge Temperature Sensor and it started but when I tried it again it would not start.
No check engine light comes on while it’s running unless I disconnect a sensor like the Air Charge Temperature Sensor, than I will get a light in the dash but goes out as soon as I plug the Sensor back in.
One of my mechanic said he thought it might be the Ignition Coil.
I’m really just thinking about replacing a bunch of the sensors and even the Engine Control Module (Computer)
My next step is trying a new Ignition Coil and or the Ignition Control Module and see what happens.
Any thoughts or ideas would be great
I just love my Explorer and don’t mind spending the time and money it will take to get it going, I just put a new transmission into it 6 months ago and a $500 sound system in it a month ago, I hate to give up on it.
