Easy easy easy... I've been there several times... The big problem is that the spindle lip sits inside the steering knuckle and time and rust will really keep it fused together. You need to use a slide hammer puller (free autozone rental)... Put the large spindle nut back on the spindle and lock the jaws of the puller on the nut... A few pulls later the spindle is out and you'll have a smile on your face.
The 1st time I removed the spindle I pried it off
Spindle Removal 1
Spindle Removal 2
TIP: Get some antiseize and coat the spindle lip and mountin surfaces to help make the next removal even easier.
