Here's the plan | Ford Explorer Forums
Here's the plan
dcarp
Washington DC
'01 Sport
Guys, when I return to the states from my tour here in the UK, I plan on diving head first into my explorer. so, here's the plan (what am I missing?):
Front:
Ranger Edge 3" lift spindles
1" torsion twist
Rear
Spring over axle conversion (4.5" lift correct?)
3" body lift
That should give me a ~7" lift. The plan is to put 18" wheels, but I'm not sure what size tires. Are 37"s too big or should I go with 35's? what is the equivalent tire size for an 18" wheel?
do i need to do anything with the tranny?
Yes it is a two wheel drive and it will likely not ever see the off road. I'm planning to be more for show.
Thanks in advance!
u need a helmet for that.
Thanks in advance!
for show? then all body lift ;) ehehe.. 5" pucks would probably work!!
wel since this is for show, then 37"s and just dont try to flex.
erp, dunno if thers such a thing as an "equivalent" tire size for an 18" wheel
Neh.. but u need a regear on the rear axle, the appropriate ratio would probably be 4.88s
a SOA conversion gives more like 6.5 inches from what i have heard.
if that's true, how should I level out the front to the 6.5" lift?
also, would the 37's rub while turning?
