jjt52
- October 29, 2001
- charlotte, nc
- 93 EB 4x4
When I first start this 93 EB Automatic the rpm races to 1800 and then settles down to 800. Then I put it into OD and it races up and settles back down. Driving is fine. When I shift into reverse or neutral or park, it races up and settles down. What's going on?
I stopped at a Ford dealer to check it out to make sure it was OK to continue my trip home. They say it'll be allright to drive but they said it appears that I need a transmission modulator valve, and an idle air control valve. They also noticed a swollen vacuum hose that needs to be replaced. If I wanted it done right then, it would run about $400. That's right 400 bucks.
Could someone explain all this to me? Its obvious that a swollen vac hose should be replaced, but why both a modulator valve and IAC valve? And why 400 clams?
