Big D from CT
- May 28, 2012
- Connecticut
- 1999 Ford Explorer XLT
Hello. First time poster, here. I've decided to seek help, from the great community of fellow Explorer owners, on a matter concerning an annoying vibration issue I experience on the highway. Before everyone jumps down my throat, I've already searched countless threads on here for a solution. Some share the same symptoms. But ultimately, many of the things suggested, I've already replaced or checked. Let me begin with what I'm experiencing.
This problem is mainly caused when I hit above 70 on the highway. Which also happens, to a lesser degree, and with sporadic frequency, on side roads. It begins with a feeling of something knocking around under my feet. It isn't provoked by bumps or road imperfections. It just happens to do this sporadically when driving off the highway. Then when I get on the highway, as soon as I hit 70, the knocking gets more pronounced. Followed by a tire out-of-balance, vibration feeling. Here's the thing, though. I purchased this Explorer about a month ago from a private seller. The thing was in great shape, so I pounced on it.
Tires looked practically brand new. The next day I took it on the highway (there wasn't a highway near where the seller lived) and I immediately felt the out-of-balance tire shake. So I took it in to get the tires balanced. Didn't fix my problem. Next thing I do is replace the entire brake system with new rotors and ceramic pads, figuring that maaaaybe the off chance that the brake pads were catching the rotors wrong. Or maybe the rotors were warped and causing the brakes to hang up. *BUZZER* WRONG AGAIN! So then I take my Explorer to a mechanic friend of my girlfriends father. He suggested I replace the front and rear shocks. I also had him check out ball joints, control arms, tie rod ends and basically anything he would think would be causing this to happen. And the tab keeps rising!!!!! Then I decided to pick up a used front drive shaft from the junk yard because the one on the truck had the inner tube of the drive shaft detach. Apparently the junk yard drive shaft was........JUNK as well!!! Same inner tube detachment. So I kept the drive shaft off completely on the off chance that it was a drive shaft related vibration. 3 STRIKES and I'm going out of my mind trying to figure this out!!!
Reading through several car and truck forums, I stumbled upon many people that suggested road force balancing. I decided to give it a go. What's a little more money being dumped into a vehicle I thought was mechanically sound? The mechanic drops an A bomb on me...........THE BELTS ARE SHOT IN 3 OF THE 4 NEW LOOKING TIRES!!! Turns out, from digging through many a receipt that the seller provided, that the tires had only 6,000 miles. But they only drove that vehicle 6,000 miles in 6 years! So it all made sense.
Friday, I had brand spanking new tires installed and balanced. Took it on the highway, and voila!!! My problem was solved. Or was it..................
Today I'm on the highway, and the knocking and a less prominent, but still evident vibration, under the floor starts up again. I can't catch a break!
It's much better than what it originally was, with the bad tires. But I've owned enough vehicles to know what doesn't feel right or normal. The truck feels great 70 and under. It drives like a normal vehicle. But once it hits that 70-75 mark, it feel like a totally different beast. Accelerating faster seems to make the vibration subside. I'm at my wits end. PLEASE HELP!!!!!!!!!!!
